1 - 16 of 16 Posts
I wasnt too sure if this would be the appropriate forum for this topic but i was wondering what kind of fuel you guys pump in your tc's? regular,plus or preminum? And also do gas stations really matter? I been pumping Safeway fuel 91 since i got the TC and was wondering if it really is worth it or not since the gas prices now days.
· Former '05er
I run the cheapest 87 I can find, and it works just fine. I get 26 mpg around town and almost 30 mpg on drives to the City (all freeway, 100 miles each way). There is no good reason to use more octane than you need, it just lightens your wallet.
The only caveat is, it is prudent to run an injector cleaner like Chevron Pro-Gard or Clean-Up, Red Line SI-1, or BG44K every 5 - 10k miles. I typically use Chevron, but have used both the Red Line and the BG products. BG is the most expensive at about $16 per dose. Chevron and Red Line are about $7 a dose and are widely available.
I saw a history channel special on gas and oil transporting. They said all gas is the same, It is shiped in long pipelines to places all over the country. Form there it is pumped into holding tanks were different oil companys add there additives. Then it is put into trucks and sent to gas stations. So I just buy the cheapest 87 and once in a while add some conentrated techron.
there is no need for running anything above the 87, which is what's required for the tC, i think. i mean, you can get a 91 or 93 or premium or whatever it's called, but it's just wasting money and really, there's a debate whether it can actually do more harm to your engine, since like Zero said, it has a higher resistance to burn. once you start modding and adjusting your spark timing and whatever you might switch over to premium
i dont get it then. ive been hearing stuff about how 91 premium can hurt the car. i've always thought the higher octane the better because you have less chances of early detenation. yes, running higher octane fuel might not do anything for the car performance or mileage wise, but you have a lower risk of early detenation. you go to any manufacturers website and they always have the recommended fuel for the car OR higher. recommended gasoline for the tC is 87 octane OR higher. same goes for cars that are 91 premium recommended. so how will higher octane fuel be bad for the engine when the manufacturer says its ok?
Why not just use chevron 87 instead of the additives in cheap gas?
Just curious....
QUOTE
i dont get it then. ive been hearing stuff about how 91 premium can hurt the car. i've always thought the higher octane the better because you have less chances of early detenation. yes, running higher octane fuel might not do anything for the car performance or mileage wise, but you have a lower risk of early detenation. you go to any manufacturers website and they always have the recommended fuel for the car OR higher. recommended gasoline for the tC is 87 octane OR higher. same goes for cars that are 91 premium recommended. so how will higher octane fuel be bad for the engine when the manufacturer says its ok?[/b]
while unnecessary, higher octane will NOT hurt your car or your performance
· Former '05er
Just curious....
It's 8 - 11 cents a gallon more expensive. I make up the $7 for the cleaner in 2100 miles, so I get 2900 miles free. Simple economics from my perspective.
· Former '05er
Ford says using anything greater than 87 octane in their standard trucks will void the warranty. I don't know why this is, but that's what they say. Toyco doesn't say this.
I have seen guys dyno with extremely high octane fuels when they didn't need it (117 when 105 or 107 would have been fine) and actually lose power, but I doubt there is any difference in performance between unleaded pump fuels.
· Former '05er
I think it would be hard to do with the tools typically available to a dealership, but there's always a way to find things out. Social engineering is a great tool for learning things you wouldn't otherwise get people to talk about.
QUOTE
Ford says using anything greater than 87 octane in their standard trucks will void the warranty. I don't know why this is, but that's what they say. Toyco doesn't say this.[/b]
ive never heard that before...thats pretty messed up
QUOTE
I have seen guys dyno with extremely high octane fuels when they didn't need it (117 when 105 or 107 would have been fine) and actually lose power, but I doubt there is any difference in performance between unleaded pump fuels.[/b]
i could see how it could cause ignition problems when using extemely high octane when not needed but not with pump gas
Originally posted by lo bux racer+Feb 22 2005, 10:03 PM-->QUOTE (lo bux racer @ Feb 22 2005, 10:03 PM)
<!--QuoteBegin-Zygote55
Just curious....
It's 8 - 11 cents a gallon more expensive. I make up the $7 for the cleaner in 2100 miles, so I get 2900 miles free. Simple economics from my perspective. [/b]
OK. I just find it easier to use my chevron card
1 - 16 of 16 Posts
