Given the injector flow numbers from the Factory Service Manual (FSM), fuel pressure of 44 psi (minimum FSM spec), BSFC of .55 (typical supercharged brake specific fuel consumption), 6psi boost, and an 80% duty cycle, the maximum crankshaft horsepower these injectors support at minimum flow is 158. That's less than stock for a reason I explain below. Best case is 205hp if your base fuel pressure is 50 and your injectors are pumping out the maximum 368cc/min. The New Car Features book says fuel pressure is 47.0+/- 0.47 psi. That means 197 hp at 6 psi boost and 80% duty cycle, 247 if you want to flirt with lock up at 100% duty cycle.
With no boost, the stock injectors at all mid-range values should easily support 236 hp at 80% duty cycle.
So you guys thinking about forced induction should be expecting to at least replace the injectors.
There's another very problematic issue with the fuel system. There's no pressure increase (or decrease) with manifold pressure. Typical forced induction systems have the fuel pressure set to a base value, and the fuel pressure regulator is used to maintain that pressure above the absolute pressure in the manifold. This means at idle, fuel pressure is below the base setting, but on boost the fuel pressure rises above the base with the boost pressure. It keeps the pressure differential across the nozzle (or pintle) constant. This returnless system does not do that. It sets fuel pressure to a fixed value and keeps it there. So all the fuel maps are designed knowing the fuel pressure is fixed.
Not bad for the stock system, but when you add boost the pressure differential across the nozzle tip drops and your maximum flow actually decreases. So increasing boost appears to reduce the fuel available to the engine.
Adding boost to this engine is LOT more complicated than it first appears...Jotech is doing it the easy way, scrap everything from the stock system and start over. I wonder what TRD is struggling with to get their supercharger reliably producing power with this configuration. No wonder it's delayed.
