1 - 11 of 11 Posts
Since I know that RMS is all that matters in an audio subwoofer system (and I already know that someone is going to say that I am wrong but whatever)
Anyhow, I needed to know if the TC's alternator would be strong enough to withstand that kind of continual wattage. Now I know that eventually if it can handle the wattage, the alternator will become weak and I will need to get a new one. Otherwise, I would be ok.
Just wanted to see what you all knew about it...thanks.
Matt
No you dont need a cap with 300 watts rms. i doubt that'll even dim ur head lights. just run 8 gauge wire with a 30 amp fuse you'll be fine. If your interior lights dim when the bass hits when the engine is running, think about a 1 farad. Good luck dude.
Here is what my system will consist of...in case you all were wondering.
Lightning Audio Strike 12" SVC X 2
Phoenix Gold 4-Channel Amp w/ 4 Guage Power Wire, Etc.
And of course the box and etc...I will post pics when I am all finished.
Matt
Unless the capacitor has some feature you like (voltmeter, LED's, etc) your better off spending your $ on something else. Capacitors can never charge to a higher voltage than is available so they really can't help a charging system that is not up to the task.
I personally just installed a 700 Watt system ([email protected]% distortion) and have no problems. If the amps were rated using the new standard my system is 1028 Watts ([email protected]% distortion).
I would ask any manufacturer that recommends capacitors "why wasn't the amp designed right in the first place?" The idea that you need to give a guy another $100+ for a part to make his amp work right never set well with me.
Unless your amplifier is pulling more than 40-50 amps. You probably shouldnt need it.
But a 1 farad cap can only help.
You can say a capacitor can't hurt, but it really doesn't help. Capacitors do not generate any current (alternators do). So there is no current demand threshold that would qualify a system for needing a capacitor. All energy needed to move a speaker ultimately comes from the alternator.
I'm sure Ohio Generator can produce one if they have already. They make some bad ass alternators. Just be prepared to pay for it.
1 - 11 of 11 Posts
