1 - 20 of 22 Posts
In George I Trust
I'm throwing this thread up on this site from over on ScionLife. Some people may find it very useful. Giving credit to where credit is due, The_Instigator is the member that posted this on ScionLife. I will be removing from his thread the personalized SL touch. We don't need that here.
Tools needed:
socket wrench
1 1/16" socket
10" extension for said socket
The tC trans is interesting since the "fill" plug is parallell to the ground and quite low on the car making filling very tricky. The best way around this is to use one of the other plugs on the tranny that just so happen to be on top of the case within easy reach. The reason I am starting the DIY with this step is that you want to make sure you can get fluid back into the trans BEFORE you drain it. Nothing is worse than draining the fluid only realizing you have just stranded yourself since you cant get any fluid back in. The easiet place to refill the tranny from is through the reverse sensor on the top of the trans case located here:
You will need a 1&1/16" socket and a 10" extension in order to get this out easily. I also found that removing the bracket located nearby made getting to everything a lot easier:
You can see how much more room there is with the bracket and wiring moved away:
Remove the plug and loosen the sensor but dont remove it completely yet. Go ahead and snug it back down for the time being. This step is just to make sure you will be able to refill the tranny with fluid.
Now comes time to drain the old fluid. I made the mistake of removing the reverse sensor first which let air flow easily into the tranny form above and was greeted with thick smelly and slimy trans fluid gushing out from the drain plug. By leaving the fill plugs closed, the fluid will come out much slower saving you many many paper towels and gallons of Simple Green.
Unscrew and remove the drain plug circled in green to get the stock fluid out and into a drain pan:
After your fluid has drained, reinstall and tighten the drain plug.
While you are under the car, go ahead and remove the "fill" plug circled in red in the picture from above. We will be filling the fluid from the top of the car but by having the fill plug out, we can guarantee we wont be overfilling the trans. When fluid starts coming out of the fill plug, you know you are good to go.
Go back to the top of the car and remove the reverse sensor and put it somewhere safe. Use a long funnel and fill the tranny with the new fluid. I used just under 3 full bottles of Redline MT90 before I had fluid come out of the "fill" plug.
After the tranny is full of new synthetic fluid goodness, tighten everything back up and make sure your reverse sensor is plugged in. If not, your reverse lights wont come when you are in reverse.
As always, be sure to use jack stands when working under the car.
Very nice tech. Sticky this so it will be easy to find in the future
Tech your so informative and full of awesome. LOL
In George I Trust
It's no problem guys, but I just copy pasta'd this. I'm not going to take credit for the work the original poster did to make this post possible. You want to thank someone, head on over to SL and thank the original guy. I'm just spreading his/her work.
hey i have a problem you said you use a 16mm socket wrench i dont get how you unscrew the sensor the screw is really big and also for the tranmssion what size are those screws?
hey guys,
newbie to working on his car. i was trying to remove the drain plug to the transmission but i'm stuck. my socket wrench wont fit in that tight spot. my adjustable wrench wont catch on the bolt. i need some help and advice if anyone has any. i know it may sound stupid but im trying to learn. thanks everyone.
QUOTE (dnaval4684 @ Jan 13 2009, 09:37 PM) index.php?act=findpost&pid=447803
hey guys,
newbie to working on his car. i was trying to remove the drain plug to the transmission but i'm stuck. my socket wrench wont fit in that tight spot. my adjustable wrench wont catch on the bolt. i need some help and advice if anyone has any. i know it may sound stupid but im trying to learn. thanks everyone.[/b]
use a standard box wrench or something...i would bet it is 12 or 14mm so get one of those....
IS this an automatic tC or 5-speed. My wife drives an auto tC and I would like to know if anything is different. Hopefully not, seems easy enough. Thanks.
QUOTE (kyledye25 @ Sep 26 2009, 04:14 PM) index.php?act=findpost&pid=494756
IS this an automatic tC or 5-speed. My wife drives an auto tC and I would like to know if anything is different. Hopefully not, seems easy enough. Thanks.[/b]
Extremely different. Auto fluid is good for AT LEAST 60k. Most new trannys have either world standard or Toyota T-IV, which is normally good for 100+k. Unsure of what the tC has but my guess is T-IV.
Eric
LED Maniac
QUOTE (kyledye25 @ Sep 26 2009, 01:14 PM) index.php?act=findpost&pid=494756
this is ONLY FOR A 5-SPEED.
automatics won't really need a transmission fluid change until well over 100+K
Thanks for the info. I was actually just at the Toyota dealership and they said the power steering fluid is dark, which is understandable. I know thats a small problem with the tC. But they also said that the tranny fluid could need changed. So I went out and bought the Toyota tranny fluid and power steering fluid and plan on doing both today. Our tC has just over 60k on it. I know the tranny fluid shoud last over 100k but I figured it wont hurt to change it. Is there anything on here for changing the fluid on an auto tC? I already bought the stuff might as well do it. Thanks.
This is the second time I've read this post only to realize that it is for the manual transmission, NOT automatics.
What we need is a DIY for automatics or a link to the one on this topic and for the title on this topic to say that this is for the manual transmission.
i cant find this stuff anywhere, only royal purple, which i learned was bad for the tranny after i put it in
Hey, sorry to bump a somewhat old thread but my gf just got her scion and it has 70000 miles on it. It didn't come with an owners manual so i'm just wondering when it is supposed to be changed. thanks for the help.
It's a manual. Another noob question but do I have to go to the dealer for the fluid or can i get it at like O'reillys? Sorry I don't know anything about scion's yet.
Thanks for the DIY :D I already got 3 quarts of redline here, and changing it saturday (luckily I have a pump for the fluid).
I know it's kinda late for the answer volleyball_lover but you might wanna call and check if they have it, your looking for "Redline MT90".
You can order it at: Red Line Synthetic Oil - Gear Oil for Manual Transmissions - MT-90 75W90 GL-4 Gear Oil
They also have a Redline dealer locater on their site that you can search for local stores that have it. Stores like Advance Auto and Pep Boys usually don't have it.
I can't get the stupid drain plug off. I first tried a 1/2" drive breaker bar with 24mm socket, but it wouldn't fit in that tight of a space, then I tried a regular ratchet and next a crescent wrench, again neither fit. I saw someone else had the same problem and a box wrench was recommended; I tried that and am still having problems. Can any of you tell me exactly what method you used to get the drain plug off? I'm thinking of getting a serpentine belt wrench, but have spent a lot of money on tools already and would like to know what worked for others before I spend more. Thanks.
1 - 20 of 22 Posts
