AS you guys know I got the DC Sports tower strut bar...and installed it myself.
That was about 3 weeks or so ago, give or take. Well about 2 weeks ago I heard tapping sounds coming from my engine, and I thought maybe I had a bad tank of gas due to the effects I thought I was having. (Lo-bux you know what I'm talking about) While I still might have had a bad tank of gas...here's what the sound *actually* was...since I decided to have the dealership check it out....
The vacuum switch or whatever switch that is on the engine was just barely brushing against the bottom of the bar. The ticking coming from that switch was resonating into the strut bar and through the strut towers and being fed directly into my car. And lemme tell you...it was loud enough to cause concern.
Service people fixed it with some foam against the bottom of the bar in that location. Caused the vibration to stop being transmitted into the bar, and into the car. So long story straight...if you guys install this bar you might need foam. I believe the hotchkis bar sits a tad further back behind the engine and doesn't brush up against this switch/valve/ tapping thingamajiggy. Engine people probably know what I'm talking about.
Foam tape is the answer...and if that doesn't help the service people were going to unclip the valve and relocate it a tad lower. But they didn't have to. What I thought was a major engine problem...was just a design flaw in the strut bar.
