1 - 1 of 1 Posts
Customized Light Duty Caster Grey rubber wheel surface, PP wheel hub, plain bearing, with steel cover can prevent dust and string stuck in. (wheel color can be also black, qualified to pass European SVHC 2021 requirement) Grey Rubber Caster general features Grey rubber wheel highlights 鈼?Strengthen steel housing 鈼?High quality grey rubber wheel Size:50/65/75/100/125mm 鈼?Load: 40kgs-70kgs 鈼?With small steel covers 鈼?High quality grey rubber instrumental caster 1. Wheel part: grey rubber wheel surface, PP wheel hub, plain bearing, with steel cover can prevent dust and string stuck in.(wheel color can be also black, qualified to pass European SVHC 2021 requirement). 50-125mm grey rubber wheel, noiseless moving, barely with no noise, non-marking, protect floor and carpet 2. Housing part: steel housing with zinc plating Optional housing type: rigid caster housing 1) Swivel plate caster housing 2) Swivel plate with lock caster housing 3) Swivel screw caster housing 4) Swivel screw with lock caster housing 5) Swivel bolt hole caster housing 6) Swivel bolt hole with lock caster housing 3. Housing thickness: 1.5/2mm, 40kg to 70kg load 4. Grey rubber caster are widely used on equipment, tool cabinet, shelf and hand cart, ladder and so on. 5. Popular design for European and Asia market, various size, material and type for you to choose. Customer highly caring point 1. Cheap version: we can change the wheel to PVC wheel, PVC wheel will be much more cheaper. 2. Different color: normally we have grey and black color for now, if you need to change color, we will quote for you with MOQ 3. Different plate size: we can change plate size in our limit size, just need mould cost and MOQ will be higher. 4. Different screw size: for our experience, many customer want the screw size to be M8X15 or M8X25 for the 50mm screw type. We already made mould for this, so we can offer for you. 5. Chemical test requirements: more and more customer have requirements for chemical test, this type can pass the European SVHC 2021 requirement, if you have any other requirement, we can check the extra cost. More Details: Minimum Order Quantity: 500 piece/pieces for normal caster wheel Loading Port: Tianjin, Qingdao, Shanghai or Ningbo Delivery Time: About 20 workdays for normal caster wheel Sample: Available for our standard caster Quick response: Your enquiry will be replied within 24 hours FAQ 1.Q: Are you factory? A: Yes, we are factory. 2.Q: What types of casters do you have? A: Furniture caster, Office caster, Industrial heavy duty caster wheel, Super Heavy duty caster wheel, Extra Heavy duty caster wheel. 3.Q: What kinds clients do you have? A: We have many clients who specialized in CNC machines, Dolley, cart, cleaning equipment, gym equipment manufacturing etc, well accept our quality. 4.Q: Can you do OEM product? A: Yes, we can provide OEM service. 5.Q: How long warranty for caster wheels? A: All of Unionlever's caster wheels have 1-2 year warranty. Workshop Packing PhotosCustomized Light Duty Caster website:China Light Duty Caster Manufacturers Suppliers - UNIONLEVER
1 - 1 of 1 Posts
