all numbers are listed in ft lbf, unless otherwise noted. if you dont find what you are looking for here, ask someone or pm me, i have every torque spec for evey nut and bolt on the car.
Lug Nuts : 76
Front Struts : center lock nut - 35
top mount - 38
bottom mount - 177
Front Stabalizer Bar : 55
Rear Shocks : center lock nut - 41
top mount - 59
bottom mount - 103
Rear Sway Bar : 32
Exhaust : 32 (every bolt from the manifold back is 32)
Clutch : clutch cover assembly - 14
release fork - 35
transaxle assembly - 'A' bolts - 47
'B' bolts - 34
'C' bolts - 32
Hood : mounting brackets - 10
front catch - 62 in lbf
Lug Nuts : 76
top mount - 38
bottom mount - 177
top mount - 59
bottom mount - 103
Rear Sway Bar : 32
release fork - 35
'B' bolts - 34
'C' bolts - 32
