ok, i have three qustions....
1) when you are accelerating and need to go in a next gear, do you realese the gas and then clutch, or do you just clutch?
2)when you are lowering your speed to a stop, do you need to downshift all the way to first gear to stop, or can you just stop, and then put it back into first gear to start moving again?
3)when braking, do you press the clutch and the brake at the same time, or do you just press the brake?
thanks.
thanks.
