You would be right if I had been removing the display itself, but it should not break when removing the switch component assembly from the dash piece. It did. The entire board assembly was still quite safe inside its housing when the display cracked. I call that defective.Originally posted by basilisk4@Apr 18 2005, 06:02 PM
Don't you mean warranty fraud?
If I remove the valve cover and it shatters in my hand using normal tools and procedures, it's a warrantable defect, and I would make a warranty claim.Originally posted by basilisk4@Apr 19 2005, 06:38 AM
That is not normal use. You broke it, and it was completely your fault. That is not a defect in the legal or logical sense. I did the same thing, and was really pissed, but that doesn't make warranty fraud OK.
So lance does my extended 10 year 100,000 mile cover this kind of problem.Originally posted by lo bux racer@Apr 18 2005, 05:33 PM
Yeah, that damn thing is unbelievably fragile, and I've been working on electronic gizmos professionally since 1979. Warranty is a beautiful thing sometimes.
