1 - 10 of 10 Posts
anyone know where i can get a camber kit for our car? i cant get it aligned till i get one..
Tein part number PRY71-31S70 is the part number for their pillowball mounts. However, these probably won't work with OEM style springs. So far, this is the only camber kit I've heard of for the tC. That doesn't mean they aren't out there, just that this is the only one I've seen so far.
much thanks
Your camber is probably fine, if you have the toe in set you will be ok.
If you still happen to see abit more inside tire edge wear, run a couple more pounds of air pressure and haul arse around more corners to even it out, really:)
yea i took the car to goodyea, they said it couldnt be aligned. i saw a camber kit made by hotchkis, for like over 200..
It can't be aligned to OEM specs. That's what they should have said. It's not a big deal, just do what Rick said and all will be well.
lmao are you encouraging speeding?
You don't have to speed to go around corners faster...
1 - 10 of 10 Posts
