1 - 2 of 2 Posts
My son has a 2008 scion that he recently had a slight misshap in the ice. It bent the driver side control arm where it connects to the hub. While replacing the control arm, we broke loose the welded nut (completely encapsulated) at the front of the control arm. Has anyone delt with this and how did you get the nut out and new one back in place.
Thanks.
If you are removing the control arm anyway if the stud is on the arm itself you could always grind it off and get it out that way. If you have to preserve the stud you might be able to very carefully cut the nut off with a rotary tool. Other than that I don't really know.
1 - 2 of 2 Posts
