I highly recommend a little reading assignment for some of you guys.
Maximum Boost
by Corky Bell
He explains in detail how doubling the output power with forced induction only results in 20% more load in the most critical part of the power stroke. This is not speculation, all the formulas, etc are explained in detail. The added load is compressive in nature and not the most the most important aspect of engine design.
Inertial loads, which are not much of a factor if at all in adding FI to an NA engine, are critical aspects to consider when designing any piston engine. Over revving due to missed shifts or raising the rev limit are far more damaging than FI could ever be. As an example raising the rev limit from 6k to 7.2 k results in a 144% increase in inertial loads wether or not FI is added.
BAD tuning, over revving, improper heat management, poor maintenance, etc, kills far more FI engines than adding a reasonable amount of boost ever will.
Maximum Boost
by Corky Bell
