TL;DR my 06 tC is very quickly overheating at seemingly random times after driving just fine for a while, and then the temperature immediately goes back down after stopping for a few seconds. So far I have replaced the thermostat, radiator cap, serpentine belt, water pump, and both radiator hoses have been checked and seem to be fine. Also, I have done a compression test on each piston and they are each making 150+ pounds, so no head gasket issues.
Here's some more details:
Right before I went back to college after Thanksgiving break, I replaced the serpentine belt on my car.
About an hour into my drive back while going up a hill, the radiator hose blew off and sprayed antifreeze everywhere. I wasn't paying attention to the temperature gauge at that point, but after I quickly saw it was overheating and pulled over, put the hose back on with an additional hose clamp, filled it back up with coolant, and went the last 4 hours with no issues.
At college, I drove it around a little with no issues, nothing more than 5-10 minute drives though.
On my trip back home, everything seemed fine, but then I stopped at a gas station 3.5 hours in and my car overheated again shortly after I got back on the road. I stopped and let it cool down (which took a while) and then went another hour until it overheated again. This time I stopped and unscrewed the radiator cap a bit after it cooled, and that barely got me the last 30 min drive home.
At home, the overheating had become normal, as the temperature would start to abnormally climb. It would still take a while to cool down, however. I then replaced the thermostat and radiator cap. These seemed to help, but did not solve the problem. The car would still overheat, but now randomly and quickly, and would go back down just as quickly after I let off the gas and/or stopped for a few seconds. It takes big hills just fine, but then it will overheat on a flat road at 35 mph. The heat also seems to go out when it is overheating, even though there is plenty of coolant. The only pattern I can think of is that its more likely to randomly overheat when I start driving before its warmed up all the way.
I did a compression test on each piston and found no problems, as well as replaced the serpentine belt (again) and the water pump yesterday, but the same thing happened again on my drive to work this morning.
The only thing left in the system to replace is the hoses (which I looked at and seem to be totally fine), the radiator, and maybe the a loose connection in the temperature sensor? I have never been able to recreate an overheat in the shop so I don't actually know if its overheating, but when it does start it seems correlated to how hard I push the gas pedal, so I doubt its the sensor.
Any time I put coolant back in I ran the heat at full blast and got all the air bubbles out, so its not that either.
I'm a broke college student running out of money and options, please help. Thanks for your time!
