1 - 2 of 2 Posts
Hello all,
On my 05 TC I've been told previously that the alignments so bad (tie rods i believe) that they couldn't even PERFORM an alignment on it when I purchased new tires, because the inner sides keep rubbing so bad and blowing tires...
And NOW, after a going over a bad dip, there's a constant metal grinding noise seemingly coming from the passenger side. Car SEEMS to sway a little at higher speeds with the noise sounding more pronounced, and slightly low-THUnK-low-THUNK rhythm at slower speeds.
Any ideas?
Thanks!
You could check your sway bar links or struts might be the the issue. Also check your brakes for the grinding noise.
1 - 2 of 2 Posts
