41 - 50 of 50 Posts
My AC is not cold at all. I even blasted it for a few minutes thinking that it needed to get warmed up. No such luck. The day wasn't even hot — I was just trying it out. After 4 years, my 2000 Cavalier's AC worked better than the tC's. Of course, that's the only thing it did better.
Are you all aware that turning the fan up to a higher setting tends to actually make it feel less cold? I've found (in every car I've ever checked) that the middle settings work better than the highest ones...
Yes.
Turning the fan up doesn't turn the A/C up...all it does is move more air over the same amount of cooling.
Thanks for the explanation of why -- I made several attempts earlier, but couldn't put it into words that would've made sense to anyone other than me.
no problems with the a/c... cold in the car in about 2-3 minutes.. even if it's 90 degrees outside.. in 5 minutes the side windows are fogging over outside..since it's so cold I think i saw reindeer hanging out in my backseat..
You have a better A/C than me....and a bigger back seat.
41 - 50 of 50 Posts
