1 - 7 of 7 Posts
After I park my car in my driveway....say after a drive of 10 miles or so...
I notice a water dripping..may be oil dripping....or fan sorta noise for a minute or so....when car is completely turned off...
is this normal ?
thanx a lot guys for helping a newbie here
if its water, it is most likely from running your defrosters. defrosters use the a/c to dry out the moisture in the air, hence the residual water build up. the fan noise is just a fan kicking on to continue the cooling down of the engine after running.
since i've not heard the cooling fan come on without the key in the on position.. the other noise that it could be is the emissions pump in the fuel tank doing a leak test.. it's in your owner's manual.. from what i understand from the manual, it's a motor and a whooshing noise.. i've never hung around the car long enough to hear it..
1 - 7 of 7 Posts
