1 - 2 of 2 Posts
Hello All:
I finally installed my Panasonic head unit today...thought it would be a 20 minute job but it took 2 hours....at the end, it was all worth it. It sounds great compared to the stock radio.
Just a heads up to anyone installing an aftermarket head unit...with the scosche bracket, you will need to cut/take the unused tabs off completely. Sand it down so that they are even and flat with the perimeter of the bracket. If not, you will not be able to put the center dash back in.
2nd, you will need to cut and sand the inner side of the "ears - the two side mounting brackets" It is a 4 inch straight line plastic on each ear bracket which interferes with the pocket.
lastly, on the back of the bracket where the two ear brackets connects to the rear of the pocket, you will need to cut the middle of the hole so that the hole will fit into the nipple.
Hope this helps any future installers....
Any questions, shoot me a PM...I will gladly help
1 - 2 of 2 Posts
