ok heres the deal, im pretty sure i made up my mind on just boosting my Tc. im pushing 90k miles here in a couple weeks and i know its best to do a rebuild. as far as the engine goes i havnt had an issue with it at all except i got an oil leak on my timing cover seal.
ive done a fair share of researching and what people are mainly saying is
"Main things to swap are bearings, piston rings and all the gaskets and seals."
is that it?
well here is the list of misc. things im thinking about getting just verifying it with the community.
2006 SCION TC 2.4L L4 : Engine : Engine Kit Gasket Set
DNJ ENGINE COMPONENTS
Price $63.99
2006 SCION TC 2.4L L4 : Engine : Crankshaft Main Bearing
or there is 2 master rebuild kits on the site
Price - 386.79$
and....
anyways what direction would you recommend me going?
oh and from this website shipping is 140$ so i would like to get it all in one shot
is that it?
Full Upper and Lower Set; Includes: Head, Valve Cover, Intake, Exhaust, Rear, and Oil Pump Gaskets; Valve Stem, Cam, and Timing Seals
Price: $124.99
2006 SCION TC 2.4L L4 : Engine : Piston RingsPrice: $124.99
Price $63.99
have 2 choices between
DNJ ENGINE COMPONENTS - 34.79$
SEALED POWER - 94.79$
2006 SCION TC 2.4L L4 : Engine : Connecting Rod BearingDNJ ENGINE COMPONENTS - 34.79$
DNJ ENGINE COMPONENTS - $30.79
SEALED POWER - 19.40$
2006 SCION TC 2.4L L4 : Engine : Camshaft BearingSEALED POWER - 19.40$
DNJ ENGINE COMPONENTS - 36.79$
if you add that up, your roughly looking at 292$
Description
Master w/o Oil Pump & Timing Belt Or Timing Kit- Engine Kit Gasket Set
- Crankshaft Main Bearing
- Pistons
- Piston Rings
- Connecting Rod Bearing
- Thrust Washer
Price - 386.79$
and....
Description
- Oil Pump
- Pistons
- Piston Rings
- Thrust Washer
Master w/ Oil Pump & Timing Belt Or Timing Kit; Master Kit; w/o Variable Cam Gear
Price - 644.99$
sorry for this hellashes post but im not too smart when it comes to engine rebuilding. i did alot of C/PPrice - 644.99$
