I have a honda as well, and ran across this on h-t.com... enjoy!!! Look at the torque
http://www.honda-tech.com/zerothread?id=1106370
i was reading this thread as im a bit of a n00b, and it has excellent info.Originally posted by whosthatrussian@Jan 7 2005, 08:15 AM
^ Thanks, man. That definitely helps and sheds some light on the situation. Interesting to know too. Glad to have you on this board.
DO you have a ballpark figure of maybe how fast that is for 0-60 or 1/4?Originally posted by TCtypeSlow@Jan 6 2005, 11:04 PM
I have a honda as well, and ran across this on h-t.com... enjoy!!! Look at the torque![]()
the TRD supercharger would do you nicely, by the sound of your driving application. it is designed to work with the tC, and comes complete with everything you need. it will easily help you outrace for the spot on the freeway, or jump in front of someone when you need to. and nothing says daily driver like maintaining your factory warranty.Originally posted by califax@Jan 19 2005, 01:41 PM
lubox, so i don't suppose i can add anything to the stock setup of the tc w/o doing major modifications? i was hoping to just add a turbo or supercharger. i dont race or anything, i just like having the ability to race to the liquor store before the commercials are over. im a daily driver. what do you suggest for someone and many people like me? i'd like more midrange and lowend power. any answer helps.
This car is a turn key daily driver, that does run on 93 pump fuel. I have over 11,000 miles on my tC and it is still going strong! This is a simple bolt on turbo kit with no mods done to the engine whatsoever! And this is only the stage II kit!Originally posted by lo bux racer@Jan 7 2005, 03:44 AM
There are lots of things you can do with large budgets and small displacement. Neither of those are simple bolt-on mods, those engines are highly modified and no doubt not turnkey daily drivers. I doubt either of them would last long on California 91 octane, especially with 12 psi of boost.
This is the stock fuel system with larger injectors and larger fuel pump, which drop in and are included in the kits! Obvioulsy not impossible to add if they are included in the kit!Originally posted by lo bux racer@Jan 7 2005, 07:38 AM
Not just boost, but the stock fuel system will not support much more than stock power without major mods. Fuel injectors, rails, pressure regulators, and pumps are expensive, and for the tC nearly impossible to tweak without redesigning the whole system.
Then you have to deal with the drive-by-wire throttlebody and the rest of the engine management system. It was never designed to support boost. Even TRD is contemplating a piggyback for only 40 more hp. I made 40 more hp on my Supra for nothing but about an hour's work because all the boost stuff was there and the engine was designed to support additional boost.
Not so the tC. So, adding boost means changing everything about the way it works. That's very expensive for both the devices, and the knowledge required to make them work. This is not something a home mechanic can do, and even a mechanic with advanced skills wouldn't touch this project without a pretty hefty budget to overcome the fuel and engine management problems.
Again obviously not correct! I run 93 Octane pump fuel and 12psi every day with a static compression of 9.5:1! My car is still running extremely well and i'm a very aggressive driver!Originally posted by lo bux racer@Feb 6 2005, 07:34 AM
I didn't say you can't run 12's on pump gas, I said you can't run 12 psi of boost reliably on pump gas with more than 9:1 static compression.
Glad to hear the V-8 supercharger exists on more than the SEMA Landcruiser. It still isn't listed on TRD's site, check for yourself.
Then that is quite obviously not the stock fuel system... how do you know there are no engine management problems?Originally posted by jms001@Feb 6 2005, 07:43 PM
There is no problems with the drive by wire system.
Obviously there are no fuel and engine management problems. If there are i can't find them!
Where do come up with this stuff??
When I say stock fuel system, I am talking lines, rail, and filters. How do I know there are no engine management problems????? I drive the car everyday, it drives flawlessly, gives very good gas mileage (for a boosted car anyways), and puts down the power w/o any hickups whatsoever, has not check engine lights, and not to mention I drive it to the track, which is about an hour away, run it, and then drive home.Originally posted by Obike+Feb 6 2005, 09:09 PM-->QUOTE (Obike @ Feb 6 2005, 09:09 PM)<!--QuoteBegin-jms001Then that is quite obviously not the stock fuel system... how do you know there are no engine management problems? [/b]@Feb 6 2005, 07:43 PM
1. Stock fuel system is pump, rail, lines, regulator, injectors. Pumps are expensive, injectors can be very expensive, regulators and rails are expensive. Lines are just a PITA to run, but fittings can be pricey if they are all AN. Filters are almost never a problem and they are cheap anyway.Originally posted by jms001@Feb 6 2005, 09:42 PM
I don't get you guys, what would i have to gain by telling lies???? If people buy my kit and it doesn't put out the claimed HP its gonna be all over the net! That would be bad for business and bad for my reputation! That would be stupid for me to do. I don't BS, its just not good business practice.
