1 - 4 of 4 Posts
2007 Scion TC 2.4L automatic
Check the relays & fuses, check to see if the wires are plugged into the door control switch.
See if the window control switches are in working order.
Window actuator motor is working.
Check both driver & passenger window control switches work.
Give the vehicle a several minutes to reset after the battery has been disconnected/removed from the vehicle.
If the battery was disconnected you'll have press the button on the driver's side all the way down then all the way up then a little down. This will reset it. You'll have to do that for both windows and sunroof.
1 - 4 of 4 Posts
