Hey guys,
I am trying to help my girlfriend with her 2007 TC, automatic transmission. A couple weeks ago her heater stoppped working. Here is what I have done:
1. I have bleed the coolant system multiple times following different procedures, 1 of those procedures being from a Toyota manual.
2. Flushed the coolant from the radiator and the engine block. Obviously refilled with brand new coolant
3. Checked the fuses under the hood that were labeled HTR (this is a 40Amp big fuse). Also checked the ECS fuse
4. Randomly checked the fuses under the instrument cluster. I didn't see anything directly related to the heater or the climate control.
I have seaerched Google and various Scion forums to see what people suggest.
Many people suggest changing the thermostat, BUT the car does not overheat and when i check the hoses under the hood, the hose after the engine is warm and water is in it. So i dont think it is the thermostat.
On the driver side, near the center console there are two Silver colored pipes that come through the firewall. I felt both of these with my hand and one of them gets VERY hot when the engine is hot and the other is warm but not as hot is the first one i touched.
When the climate control fan is turned on, it blows fine. As you adjust the speeds is adjust speeds at the touch of a button. The air never gets HOT and the Defroster obviously never gets hot.
What else could be wrong? I would like to thank you in advance for your help.
