1 - 2 of 2 Posts
i have a 2007 tC with 75k(ish) miles on it and a stage 1 race clutch installed (previous owners doing) the pedal is sticking to the ground and the engagement point is.... you guessed it the floor today i tried bleeding the slave cylinder. while clutch was fully depressed i opened the bleeder valve, no sputtering noise just fluid came out. from what ive researched on here im guessing its not the slave cylinder. could it be the master? if so where is it located. if not then what the heck is going on? any help would be beyond amazing have a 4 day weekend wanna get this tackled before going back to work. thanks
Discussion Starter #2
update: more research and replaced master & slave cylinder replaced clutch working like a dream...minus a broken bushing on the pedal giving it side to side play. going to a dealership to try to obtain said part if not gonna try to find a non broken one at a salvage yard
1 - 2 of 2 Posts
