1 - 1 of 1 Posts
Hi all my boy has a 06 tc and the other day the clutch pedal went to the floor and did not return. So I replaced the master cylinder and slave cylinder and bench bled the system. I'm pretty sure all the air is out of the system. Problem is when the clutch is depressed it still only returns half way. Also when car is running and is in 1st gear if I barely start to release the clutch I mean almost still to the floor the clutch is engaging. So is the clutch going bad or could this be something else. Thanks for your help
1 - 1 of 1 Posts
