Well I was looking for a 1/4 Mile time calcutor and this is the best one I found and the most accurate. Basically what it is saying that I was running 170hp on the track last thurs. night which is about right because I added an intake to it so it added about 10hp, it is also saying if the tC is stock at 160hp youll be running a 16.37... which i believe is right because if you were to run 15.7 that would mean you need 180hp which again sounds right because there is no way in hell you can get 15.7 at a stock 160hp unless you gut the whole inside of the tC. I also calculated that the car has to be at 2700pounds at 160hp to be at 15.7 which the tC comes at 2905 + your weight which im about 132 which would come out to be 3037!
Link > http://www.rx7.org/Robinette/et.htm
